Any write up for how to set the tining on a 3.0 engine?
#11
If the cam is an issue, you'll know immediately.
True. Later is better.
Then why are you pulling the head?
#12
The car has a loud ticking sound, thinking it's a bad valve. Tryng to figure out if I want to try fixing it or not. The worse case would be to have to pull the head and replace valves..
question on another topic: when I stand in front of the car which O2 sensor is downstream left ?? passenger side? or am I in the car which would be drivers side?? how does the manufacture define them? have a bad O2 sensor in bank1 01 on My current A6 I think.. thanks
#13
In the US, left side is driver's side; right and left are determined as if you are standing behind the car, not in front. Bank two is right side.
#14
No sorry not familar with the leak down test, Is there a write up some place??
explain, I assume it tests how long the compression stays in the cyinder? Is it just using a compression tester?? But if I have a ticking something is wrong with either the CAM or the valve I would think. If it leaks I would think the timing would be off only..
#15
A valve is a simple thing. There isn't much to fail. It can be either burned or bent. That's pretty much it. In either case, a leakdown test would show that (not to mention that you'd be misfiring and throwing a CEL). I can't imagine how a clacking noise would be a valve.
To learn about leak down, try a google search. You have the basic idea, but a leakdown test is more than just *if* there is a leak, it is very helpful in determining *where* the compression is going.
#16
Directed to the poster
If you hear a clacking noise the most simple logical step would be to pull the valve covers and check all the cam lobes for wear, hell use a wooden stick or 1/2" PVC up against your ear to locate the source or VC side and go from there.
sw20T
16
08-27-2003 12:04 PM
