Anyone with a 3.0 solve a mulitple random misfire issue lately?
#14
since it could have been a batch full batch of CP's together.. but maybe its the turbo lady visiting him, and confused over the fact that its a 3.0 lol
#15
was cold and stumbled on acceleration. Replaced the injectors and problem went away.
Misfires *generally* with fuel delivery esp since you've changed everything else that is electrical/spark.
#17
cylinders. It will have about 11 while all others may have 3 or 4 misfires before resetting. Could one cylinder cause the others to misfire? And again, I never feel any out of the ordinary vibration or notice any performance loss.
I'm thinking about blowing a hundred or so and replace both CAM Position Sensors, Coil Pack #1, and the Coolant Temp Sensor.
BTW. Here's my full system scan:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0001
Coding: 0016711
Shop #: WSC 63351
8 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - Lower Limit Exceeded - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 008 - Implausible Signal - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 008 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 002 - Lower Limit Exceeded - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04495
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 K
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
1 Fault Found:
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 05418
WAULT68E13A164327 AUZ6Z0B0252820
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 16200
Shop #: WSC 63351
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
01403 - Glass-Break Sensors: Rear
36-00 - Open Circuit
End -------------------------------------------------------
The immobilizer thing is getting on my nerves too. I haven't found out what exactly is causing the low signal - they key or a system issue. Don't want to go to the dealership without knowing what to do first.
Coding: 0016711
Shop #: WSC 63351
8 Faults Found:
Coding: 04495
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00013
Shop #: WSC 63351
Coding: 02041
Shop #: WSC 63351
1 Fault Found:
Coding: 03200
Shop #: WSC 05418
1 Fault Found:
01176 - Key
Coding: 00001
Shop #: WSC 00000
Coding: 16200
Shop #: WSC 63351
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
