Anyone know how to force readiness for emissions?
I have a 2000 A6 4.2
1 cat has blown the honeycomb out, therefor not allowing me to pass.
I am very broke at the moment and cannot afford a new cat+ sensors...
I would appreciate this help immensely
You can install an oxygen sensor spacer, which will get rid of your check engine light and the cat code. Cheapest fix for your situation.
How does your state test for emissions? Do they read engine codes and readiness codes? Do they put a sniffer to the tail pipe? Or do they physically bang on the cat to see if it's hollow?
I have tried the spacer, tried 2 in fact... one with a mini honeycomb inside and one without... neither worked.
This might work but it sounds like a stretch... Too many variables etc.
Then you may also fry your ECU and be in a lot $$$ trouble.
My 2c
Cheers
Massboykie
peteypab
03-23-2005 08:16 AM
$teady$upreme
09-08-2003 07:04 PM
kam1200
06-06-2002 06:34 PM
sjames
04-26-2001 07:20 AM
