Attn: all with creaks/squeaks from the door/headliner
Most likely it's the rubber weatherstripping. The more you wash your car and don't moisturize it, the worse it gets. Silicone doesn't last very long, but most rubber care products will quell the squeaks completely. If you try it, please let me know your results.
Good idea. I'm not sure the rubber is the main culprit, because...
... adding felt tape between door and door panel helped quite a bit.
I did notice that almost all of the creaking goes away if I open the back doors. So it is either the rubber or the flexing of the doors themselves, or both.
If I have the right rubber care products, I'll try it this week.
Re: Hey Stoney - how much difference do you notice with the 628 relay?
<A HREF="https://forums.audiworld.com/a6/msgs/104772.phtml">Module 628 (vs 605) may be a worthwhile mod for some, based on more tests...</A> (check here first)
<a href="https://forums.audiworld.com/a6/msgs/123334.phtml">Long term impressions with 628 module, replaced the 605</a>
<A HREF="https://forums.audiworld.com/a6/msgs/101135.phtml">Inside a servotronic control module: electronics to control amount of boost</A>
<A HREF="https://forums.audiworld.com/a6/msgs/83713.phtml">Relay 605 (or 392) and its function</A>
<A HREF="https://www.audiworld.com/tech/elec60.shtml">Removing 605 relay, pictures!</A>
<A HREF="https://forums.audiworld.com/allroad/msgs/10660.phtml">For 2002 the 605 FAQ needs to be modified/added to</A>
<A HREF="https://www.audiworld.com/tech/elec35.shtml">Adding switch to the Servtronic control module (aka Relay 605)</A>
<A HREF="https://www.audiworld.com/forum/m/a6/msgs/28570.phtml">A6: Installed On/Off Switch for Relay 605</A>
<a href="https://forums.audiworld.com/a6/msgs/185796.phtml">Mod to turn off 605 steering boost when in Tip mode</a>
<A HREF="https://forums.audiworld.com/a6/msgs/101952.phtml">Servotronic control module: 2002 has 628, 2001 has 605, 2000 has 392...</A>
<A HREF="http://pictureposter.audiworld.com/230/servotronic6052c628-1.jpg">Servotronic pic 1</A>
<A HREF="http://pictureposter.audiworld.com/230/servotronic605open.jpg">servotronic pic 605 inside</A>
<A HREF="http://pictureposter.audiworld.com/230/servotronic6052c628-2.jpg">Servotronic pic 2</A>
<A HREF="https://www.audiworld.com/tech/pix/605wiring.jpg">Servotronic wiring diagram</A>
4RINGkingA8L
01-04-2013 09:02 PM
QuattroFan02
02-19-2003 06:52 PM
