Audi 2.7t hesitation and codes problem. Can anyone help?
I have a 2001 audi a6 2.7t. The car was chiped right at 59,000 miles by APR TUNED. I also replaced the faulty throttle body boot with APR'S bi-pipe. However, I have been having problems latley. I took the car back to APR and they said the problems were not caused by the chip. There are several problems I am dealing with. First, the car hesitates at 3,000-4,000 rpm's. When it has dones this, it usually throws codes. The two codes that it is throwing are as follows: random multiple cylinder misfire, and manufactured controlled fuel/ air metering. During this rpm interval boost normally drops then rises again. Does anyone have any ideas on what could cause this? The spark plugs, diverter valve, and mass air flow are new.
do you have more chronology? Were the DV, MAF and plugs replaced before or after the CEL? How many miles after each change (chipping, TBB, DV, etc.)?
robbie.kk
03-17-2015 01:25 AM
RolledMySTi
15
07-13-2007 09:04 PM
RingMan86
02-20-2006 02:52 PM
llonman
07-30-2005 01:29 PM
