audi a6 1999 2.8l coolant leak
i have a coolant leak were the oil cooler connects to a pipe that the upper radiator hose also connects to on the drivers side i changed the hose to the cooler and it is still leaking any ideas please help i am missing work and this is costing me alto of money
The metal pipe that runs across the front of the engine? Are you sure it is that hose that is leaking and not something above it? If you've changed the hose, the next step would be to change the pipe.
Not a big mystery. Either there is a problem with the hose, the pipe or the clamp...or the leak is elsewhere and is following the outside of the pipe down until it hits that metal collar.
