Audi A6 2.8 ATQ 2000: Fluctuating RPM while driving between 25M to 50M
#11
manual says check combi valve, vac lines etc etc for the p1411 and p1423 codes
give me a sec on getting the pdf thing to work.... got to figure out how to get you the manual without getting myself into heaps of trouble....
#15
haha no worries ill get ya, just having a full time job and getting a masters degree is tough :P
on the bright side (pun), any aquarium guys in here, you may just have a sweet affordable LED light coming your way soon.
#16
ok here are the EXACT instructions
- inspect fuse for secondary air pump
- inspect vaccum lines
- check piping from pump to secondary air injection valve (combi valve)
unfortunately no VAG-COM electrical tests, just good old fashion getting yer hands dirty.
if the fuse checks out and there are no leaks let me know, but most likely the SAI pump is possibly toast.
#17
Thanks!
- inspect fuse for secondary air pump -- Location?
- inspect vaccum lines -- there is one on the left/under the Ignition Coil Pack looks like it's toast. do you know how can I change it link/images? I have an image of it is in my first thread.
- check piping from pump to secondary air injection valve (combi valve) are you talking about the EGR Valves ?
if the fuse checks out and there are no leaks let me know, but most likely the SAI pump is possibly toast.[/QUOTE]
VGA output --> Secondary Air Injection and the Catalytic Heating Passed... doesn’t that eliminate the Air pump/SAI?
Thanks for your help!!
#18
Thanks!
Thanks for your help!![/QUOTE]
didnt know the vag said that haha missed it but yeah looks like the SAI is ok, EGR and combi valve are one in the same. ill look into that line, but the bottom line is htere has to be a leak some where, modern emmissions equipment is VERY sensative so it may very well be a tiny leak or a big one, just have to find it
THE_A6
04-17-2010 08:53 AM
mbquattro
11
10-27-2005 02:22 AM
