Audi A6 2000 2.8l quattro fuel gauge problem
hi.
So i filled my tank with 20litres of gas. My fuel gauge moved. But now it shows empty. Is there any fuse i can check or the problem is deeper? I drove about 10km and it showed empty.
Nope, no fuse.
You either have a bad fuel gauge in the cluster (most likely) or a bad fuel sender.
If you have a trip computer, does it show how many miles you have to empty? If that still works, it is the fuel gauge. There are places on the internet that you can send your cluster to for fixing.
Or you find someone with Vagcom/VCDS and do a Cluster Gauge check to rule out the dash fuel gauge otherwise the problems with the sender as george944 suggests.
Check with your dealer for fuel level sender recall; you're probably beyond getting it replaced under recall but you never know what audi might do for you until you ask!!
TT twister
10-01-2004 10:01 AM
GeTTin
02-05-2001 08:38 AM
