Audi A6 2001 2.5 TDI - Radio problem
Hi All!
My problem is, that after a battery replacement, the radio doesn't work... I've already read, that after the replacement a 'SAFE' word will come up in the display and I have to enter the radio safe code, but the radio is not turning on, the display is dark.
Is there any suggestion what I have to check?
Thank you for your great responds.
alpbal
alpbal
make sure you didnt blow the fuse to the radio .. it should show safe when you try to power it on
procedure is as follows
1. press P.SCAN and RBDS buttons simultaneously and hold down until 1000 lights up , immediately release.
2. use buttons 1-4 on the radio to toggle through the digits until the code is entered.
3. press P.SCAN and RBDS buttons simultaneously to lock it in.
the code is sometimes written on the options sticker in the trunk
common mechanic function to do this.
xkahn
02-08-2018 10:43 AM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
