Audi a6 3.0l 2003 camshaft help needed
As title says I'm in need of help for my audi.
Have a p0393 code popping and getting a rough idle and even shutoff at times. Timing belt was recently done and figure the code is right and the camshaft needs replaced. Reading around trying to pin point which sensor needs replaced exactly. Can't get a clear answer though. Is it the sensor behind head near firewall? Should be bank 2. Looking up code I get this info "P0393 AUDI - Camshaft Position Sensor 'B' Circuit High Bank 2".
Also get some misfire codes and am hoping they are from the camshaft.
Any help would be appreciated. thanks!
2013 Audi S4 code P0018
Hopefully someone can bring some light to this problem, recently got a check engine light on my 13 Audi S4 for crankshaft position sensor cam shaft correlation bank 2 sensor A. Changed the cam shaft sensor on the driver side under the engine cover and the crankshaft sensor under the car connected to the transmission and problem is still there, car drives perfect but get this weird misfire thump every so often. took it to the dealer and they want to charge 1k just to look back there and if anything needs to be replace timing wise then they have to drop the engine which we all know will be thousands. ANY input will be appreciated!
Strath44
02-08-2017 02:09 PM
Distinct
09-13-2004 03:15 AM
