Auto tranny problems - pulled some codes. Could anyone share some expertise?
18265 ----Unknown Trouble code
1236 Shift Lock Solenoid N110
Open or Short to Ground
293 Multifunction Transmission Range Switch (F125)
Incorrect Signal
526 Brake Light Switch F
Incorrect Signal
Incorrect Signal
Incorrect Signal
Those aren't Audi codes are they?
The first thing I would do is save them.....then clear them.
Then make sure you press the brake pedal at least once and then scan for fault codes....
If you post the Audi numbers it would be much better....
These are Audi numbers collected with a VAG tool.
I know they don't look like the full codes, but they are exactly how repored in VAG tool.
I tried reseting the codes and they popped up rightaway.
Thanks.
Thanks.
try to clear codes, drive a bit and read them again.
also brake sensor code might go away, if you will read codes while pressing brake pedal. Otherwise you will have to ask somebody with Bentley manual (or get one for yourself )
TheMike
06-08-2006 12:02 PM
black225TT
09-02-2003 10:02 PM
