awd to 2wd conversion?
#12
Without caveat you simply cannot say that as aero drag rises exponentially with speed. Most care as aero limited at top speed. I don't necessarily buy your argument. At 30 mph? Yea. At 80? probably not.
Note small aero coefficient (relative to others) does not mean small drag. It simply means a) less drag per unit area and b) still dependent on unit area - big cars move more air all else equal.
In any event, at best you're saying its #3 not #4 - i do believe F=MA dominates, and rolling drag, which is huge, is #2
Of course, rolling drag depends on tires, width, inflation, temperature, etc.
got numbers? I'm interested.
G
G
#13
Your also neglecting air density that will also effect drag.
you are correct in that size matters
bottom line the c5 a6 has a drag drag coefficient of .28... LOW by any standard especially for a car its size, yes i exaggerated on placing it fourth, but it in no way deserves to be first.
i dont have extensive wind tunnel testing available but i would love to see the drag vs drivetrain loss
#14
I didn't mean to imply any order at all.
Only that driveline drag is only 1/4 contributors
I know that fluid dynamics is not only complex, but occasionally fishy :-)
#15
haha its about as fishy as oil speculation on the stock market.... any one variable manipulation and you can change the outcome.
I still think that driveline drag would be the most however i have no way to prove that. i think rolling drag would be least and aero in the middle
Tim Baker
27
01-03-2019 07:38 AM
Tim in Vancouver
07-18-2002 11:11 AM
pwaug
13
03-17-2001 11:39 AM
