Baby Seat on a 2.8 A6
Old 10-24-2005, 05:20 AM
  #11
Ritz's Avatar
Default That picture doesn't look very safe...
What's to prevent your child from doing a face plant into the rear seat back if you're rear ended?
Old 10-24-2005, 07:07 AM
  #12
kkemp's Avatar
Default ????
That's how all infant car seats are installed. The seat itself is actually quite reclined, the baby is in a nearly prone position while riding in the car seat, only sitting up enough to ensure that he can easily breathe.
The seat is also wedged quite tightly into the back of the seat, it's not going to tip backward in an significant way.
Finally, the car seat is *designed* to ride up and down a bit in a crash, that's part of how it dissipates crash energy.
Old 10-24-2005, 07:43 AM
  #13
Ritz's Avatar
Default If you look at how the belt is holding it in...
It is virtually impossible for the seat to fly forward without breaking the belt or the carseat. However, if you're rear ended, the seat is going to want to travel back and up. Perhaps I'm just not viewing the picture correctly, but in order to prevent that type of motion, you'd need something anchoring the seat a bit below and behind the baby's head, no? Otherwise it simply pivots up, treating the belt as a "hinge".
Anyway, god forbid you should get into an accident with your baby in the car. I just thought I'd point that out. I could be mistaken. It's been a few years since my kids were small enough to be in a rear-facing childseat.
Cheers,
Old 10-24-2005, 08:18 AM
  #14
Senior Member
allroad'Ed now's Avatar
Default LATCH part numbers; and it's a free install regardless of age or mileage-
Here's your part numbers:
lower LATCH bracket- ZAW269005 you'll need two kits (one for each side)
Upper tether bracket- 443.887.269 again, you'll need two
upper bolt- N01.024.118 two required
upper washer- 443.887.077C two required
upper spacer- 810.019.829 two required
upper rivet kit- N90.576.301 two kits required
upper cap- 443.887.301C You'll need two; and color matched to interior color
Old 10-24-2005, 10:42 AM
  #15
kkemp's Avatar
Default The rear end of the car seat is about halfway up the seat back
The belt is attached to the top of the base, so it's belted about 8 inches off the seat bottom, and projects about 6 inches above that, so it's really not very hinge-like.
Also, the picture exaggerates the angle of the car seat, it's much closer to level than it seems.
Old 10-24-2005, 12:39 PM
  #16
New Member
der_Apotheker's Avatar
Default Re: LATCH part numbers; and it's a free install regardless of age or mileage-
i talked to AoA and they said that lower tether anchors only available after build date 09.01.99
upper tethers on all models all build
i heard someone here had a lower anchor on 98 car? is that true
let me know
Old 10-24-2005, 02:05 PM
  #17
silverkris's Avatar
Default Is the seat a Graco SnugRide?
We have one for our 1 month old and yours looks like mine.
  #18
silverkris's Avatar
Thanks for the info- I'll contact my neighborhood stealer
Old 10-24-2005, 03:34 PM
  #19
Scott Massey's Avatar
Default We had LATCH put in our A4 but passed on the A6. The seat belts work fine for forward facing seats.
Pull the belt all the way out and it will ratchet as it goes back in. Put your knee in the seat and pull the belt. This will lock it tighter than a lap belt. LATCH is only good for kids less than 30 lbs. My boy should be there before 18 months!
Old 10-24-2005, 05:32 PM
  #20
mbr
mbr's Avatar
Default The LATCH retrofit bolts to the floor under the back seat...
If you take out the lower seat cusion (it just pops out), there should be two threaded holes behind both the right and left back seats. The holes are covered with tape and the tape is painted, so it is hard to find, but you will see the square piece of tape. Peel off the tape and there is the hole to bolt the LATCH attachment onto. I got the parts from the dealer (for free) and then put them on myself because I did not want to leave the car all day for them to install them. The install took less than 30 minutes.
Quick Reply: Baby Seat on a 2.8 A6
