Bad HID Ballast?
Bad HID Ballast?
The low beam HID headlight on the pass side went out last week, so I bought a set of new bulbs from ECS
http://www.ecstuning.com/Audi-C5_A6-...ite/ES2539465/
I replaced both sides on saturday. The next day, the drivers side started acting weird. When cold, it turns on fine and will stay on. After driving for a while, everything is warmed up and hot, if I turn the car off and restart, it fails to turn on. A few times I was able to get the light to turn on after turning the switch off/on a couple of times.
I've done a bit of research and signs are pointing to a bad ballast. Any thoughts? I have the stock Osram bulbs still so I will swap the good bulb back in to see if the behavior changes.
I've also read that using anything but Philips/Osram bulbs can lead to premature ballast failure; of course I found this out after I bought the bulbs already.
Any help is appreciated!
Ballast failure can happen but it is not so common with stock. Aftermarket is another story. Again, who knows the quality and make... Check ballast wiring/connectors. Swap working old bulb into the defective side. Try to return those bulbs if you can and buy phillips.
Had the exact same symptoms on my 2003 AR. Bad ballast. Indie shop used new bulbs, but would only stay lit for a short time. Gave them back the new bulbs, put in a new ballast and the old bulbs, has been working for two years. Drivers side ballast is a bitch.
It could be a bulb. Try swapping back an old one to see if anything changes.
If it does give our customer service a call 1-800-924-5172 ex 134 and they should be able to take care of you.
Best,
Jason
Best,
Jason
LOL--it's probably worse on your 2011 but at least it's still covered by warranty unless you've already racked up 50K!!!
Just got the 2011 avant. Bought because it had 1 year and 12k miles factory warranty left. and my wife was really tired of me replacing something on the allroad each month. Now she has the ar.
Did a lot of research on the ballast issue. They get weak when old and can't ignite the hid lamps. And the older a hid lamp gets, the more voltage it takes to fire. That's why a new bulb might fire for a while an old weak ballast. That is why mechanics advise never to buy a new hid lamp until you switch l and r bulbs to confirm it's the bulb or ballast. The OPs symptoms sound just like a weak dying ballast.
Ballasts can and will get old. Just a fact of life with anything. But, the "higher voltage" you mentioned is not without limits. It will only ramp up in steps based on current feedback. At a set point, it won't fire anymore (same as open circuit). Further, it takes more current to re-ignite a "hot" bulb(one that's just turned off) than to ignite a cold bulb.
From my experience, the ballasts on Audi are some of the best to be honest. In most cases it is usually the bulb that's bad.
Unless, of course, water and other damage, beyond its normal operating parameters... Oh well, I shared my $0.02
re the used 2011 or any used one...
Thanks Jason! It is a bad bulb. I swapped sides with the bulbs and the behavior followed the bulb. I will be calling you guys.
Audiacity
9
12-20-2011 06:11 PM
