bad MAF on 2.8 30V. Is there a substitute MAF from VW that I can use?
I know that on a TT the MAF sensor from VW can be used and it is far cheaper. Is this the case for 2.8 30V? If it is, what is the part number?
You do not risk anything, but might save alot. Also if you use K&N filter, replace it with OEM one.
You need to buy a buttle of 98% alcohol, take off MAF and put this alcohol in it.
if you russian, do not forget peakles.
<a href="https://forums.audiworld.com/a6/msgs/355780.phtml">start of the post about VW MAF sensor</a>
<a href="https://forums.audiworld.com/a6/msgs/356025.phtml">Part Numbers for VW MAF sensor</a>
Enjoy!
Enjoy!
O2 sensors in the exhaust not the MAF in the air box/inlet. The whole post was about 02 sensors being replaced with VW parts.
MarkConrad
09-21-2004 08:52 PM
maaliish
03-10-2004 09:39 AM
