Bad Water Pump?
Old 10-03-2005, 08:35 AM
camikazi2k's Avatar
Default Bad Water Pump?
how hard is changing water pump for 2000 A6 2.7t and how much they go for
thanks
Old 10-03-2005, 09:00 AM
camikazi2k's Avatar
Default Re: Bad Water Pump?
i just tried to add water, i cant drive the car anymore, the whole water just drop on the ground.
Old 10-03-2005, 09:04 AM
Mums's Avatar
Default You are leaking coolant? I would try to ID where the leak is coming from.
labor for the water pump is like labor for a timing belt so....I would make sure it's not a broken hose or something first.
Old 10-03-2005, 09:39 AM
Tech Guru
4Driver4's Avatar
If it is the water pump, do a full timing belt service.
Old 10-03-2005, 09:45 AM
absolutcq20v's Avatar
Big 2nd!
Old 10-03-2005, 09:48 AM
camikazi2k's Avatar
Default $1300 for the job?
am towing it to the mechanic now, i believe its water pump because there is a sound coming out from it. i took it to a mechanic for an estimate it was $1300 for water pump and timing belt service. $400 parts $900 labor.
is that how much it go for, i looked around and water pump goes for $70-$100
and if i follow these instruction will it work wtih my model
https://www.audiworld.com/tech/eng39.shtml
Old 10-03-2005, 10:22 AM
camikazi2k's Avatar
Well the water pump dicretion in the TECH section works? even though its for 2.8
Old 10-03-2005, 12:01 PM
thomas1978's Avatar
even bigger 3th
Old 10-03-2005, 12:20 PM
Junior Member
6ULDV8's Avatar
Should be more like $900. How many hours did they quote and whats their labor rate?
Old 10-03-2005, 12:28 PM
camikazi2k's Avatar
Default Re: I dont know just gave me an estimate of how much it will cost
thats all they did, took it to my friend garage and said it will cost around $700-$900 for him
Quick Reply: Bad Water Pump?
