Bank 2 sensor 1
I recently purchased a 2000 A6 2.7 quattro. I have the following codes;
P1423 and P1411 which is the secondary air system. I was told my combi valves are causing this code.
Where are the combi valves located. I found a thread on how to clean/diagnose them... I just need to find them![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Also, I am also getting two O2 sensor codes. After I cleared my codes, only one code came back P1131; Bank 2, sensor 1 resistance too high.
I found a thread that said bank 2 was the left side of the car.......but with no reference of where you are looking at the car to determine left from right.
So, is bank 2 on the passengers side or drivers side???
Thank you all for your help
Bank 2 is Driver's Side. (DS). When referring to left or right side of vehicle, it based on position when your sitting in the drivers seat. Assuming you face forward when you drive, then:
RIGHT = Passenger Side = Bank 1 (cylinders 1-2-3)
LEFT = Drivers Side = Bank 2 (cylinders 4-5-6)
Thankyou! I found one thread that was not discriptive and confusing. If I was working on the vehicle, Passenger side/driver side is a lot more specific regardless of where you are in reference to the car. Looks like I have to replace drivers side O2 sensor, bank2, sensor 1.
Also, where are the combi valves? I don't have a shop manual for my A6 yet![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Thank you again!
Thank you again!
The combi-valves are are the two cylindrical flying saucer looking things at the back of the engine, right over the valve covers. There is a rubber hose going from the secondary air pump to each combi valve, and a silicone hose coming off a small nub on the combi valve. If you look at the back of the engine, near the fire wall, you will see the SAI pump with a hose that goes out in an almost T shape - one side of the top of the T goes toward each side of the engine - and plugs into each of the combi valves.
Sorry, don't have a picture. Hope that description is helpful.
a high vacuum source is routed through solenoid vales, then more hose to the combi valve which is a diaphram valve. if you lose vacum anywhere along that line the valve wont open.
Three A6s is not much of a problem. If you learn on one, you don't have to learn on the other two. I always have something to do, though.
