Best simple OBDII reader?
I'm shopping for a code reader and noticed that the old VAG-COM doesn't seem to get much mention any more. Which unit is considered the best buy for an '01 A6 now? Laptop accessory? My driveway mechanic days are over, but would like to be able to ID and correct simple problems.<ul><li><a href="http://www.diydiagnostics.com/">Any comments on these</a></li></ul>
an Actron code reader that I got for like $100 because I have a Honda as well as 2 VAG vehicles. Cable + software for VAG-COM were just under $200, but it is worth like 10 times the price due to the ability to log real time data (like misfires) and change the remote/autolock functions, etc.
If all you want is the cheapest way to read a code, then buy one of these but in my experience many issues require more data that a simple code and the VAG-COM fills that need. Mine paid for itself the first time I used it. Having it makes me wish something similar existed for every vehicle make on the road. You get professional service technician capability at bargain basement prices.
I looked at the link for which you requested feedback, so here's my opinion...
Your car is an Audi, and it's a '01. That means you probably have a CAN-BUS and require support for it. There is a reader on that page that sells for $150 that has the required features for your car. You might even get away with the CAN-BUS-capable device for $65.99... But I would not risk it. VAG-COM is great, because it is a hardware license for the VAG-COM software. That means you can install the software on any computer you like, as long as you use a Ross-Tech VAG-COM with it. On this forum, VAG-COM is tried and true, and even has its own discussion area. You can ask a question and get a Ross-Tech dev to answer it. You can't beat that level of answerability and explanation, especially when you consider the cost. If you really wanted to, you could also recover some of the cost by renting it out. Since it is a hardware license, you would have no legal issues surrounding the software, and we know it won't short out your ECU or any other part of your bus. It's worth the extra cash, and this is coming from a VAG-COM owner who's had very little reason or opportunity to use it
<a href="http://www.vadmobile.com">klik me</a>
I've been using their software for years. Great form factor as you don't need to drag around a laptop in the car. I leave the palm in the glove-box and grab when I need to clear codes or help a friend (for beers).
Yours is a non CAN car just like mine.. Email me if you need more details..<ul><li><a href="https://forums.audiworld.com/a6/msgs/799446.phtml">https://forums.audiworld.com/a6/msgs/799446.phtml</a</li></ul>
If DWC is looking for a simple device, why not consider one that is portable and convenient.
VAD Mobile has its own discussion area in which you can ask questions. It also produces the same Audi specific fault codes and coding options.
And you can keep it in the glove box when you're not using it...
Just a thought...<ul><li><a href="http://www.vadmobile.com">http://www.vadmobile.com</a</li></ul>
