Blinking CEL
Blinking CEL
I occasionally get a steady CEL, and usually has to do with the o2 sensor. It goes away after a drive or two. This morning I start up the car, and it starts really rough, then idles rough. CEL starts blinking and I immediately turn the car off. I let it sit for a while, then try again. Starts fine, no CEL, running as normal as can be. I know the blinking CEL, and the roughness can be a sign of a mis-fire. Should I still be concerned, now that it is running fine?
Blinking CEL means: Don't drive, you will majorly f-something up such as
burn out your cats, etc. It will only happen with a huge misfire. I know; having screwed up the plug wires on my wife's 2.8Q, two cylinders misfiring, then the blinking CEL. Now I have a rattling cat.
I just had the same thing
I reset it wit VAG com to see if it would clear, and although it stopped blinking, the CEL stayed on. I brought it to the dealer, and they replaced the plugs as part of normal service. The light is out now, and it runs fine. But the codes I had were for misfires, with no indication of an EGT sensor.
Re: I just had the same thing
I bought my 2.7t with 99,000 mi on it. The CEL light was on. I, too, thought it was just an O2 sensor. When I took her in at 100,000 for the timing belt change-out we discovered that it had actually "skipped a tooth" and had been misfiring.
youcantseeme
01-19-2007 04:24 PM
04 Savant
03-26-2004 09:52 AM
