Boost lower since getting cold. Is this normal?
As soon as it got colder, my boost went down from 19psi to 12-15. Is this normal. I had my indie check for boost leaks and no leaks found. Is this normal?
performance.
For example my setup peaks at 22psi during the summer months whereas during colder days of winter it barely sees 17psi.
but if the ambient air is colder the boost will be lower since colder air combusts easier, and you're effectivly getting the same amount of air in the engine. In the RS6 the ecu will turn up the boost above a certian altitiude to compensate for the thinner air
Maybe a noob stupid question but since this is my first summer with this car and temps are rising...
elijahallen
06-11-2007 07:09 PM
Yes/No: Is it normal for boost to spike higher during cold, winter weather than during warm weather?
VandyS4
12-15-2005 06:15 PM
ClemS4
18
01-19-2005 07:02 PM
[ej257]
04-03-2002 07:27 PM
