Boost spike at throttle cut?
I've logged my car many times, car feels very on/off. I've noticed from graphing runs. Between shifts(Tip) or just cutting the throttle after flooring it etc. The boost seems to spike a lot at times. The avg boost is down, then big spike at the end. Can this only be caused by a DV problem? Or can it be a boost leak? Doesn't seem like a leak would cause a spike. I've tested the DV's and they hold open with vacuum. I'm not sure if there is a better way of testing them or not? I've mityvac'd them open...I've pushed the diaphragm open with a socket and done the thumb trick.
Man my car is pissin me off!
Had a similar issue and it was my N75 valve
Here is a quick boost DIY setup
http://www.vaglinks.com/Docs/Audi/C5...ure_Tester.pdf
PracTTical
09-28-2008 07:16 PM
ski ya later
05-12-2006 12:08 PM
4Rings::G2 boosted::
08-22-2005 04:31 AM
Alias Unknown
07-05-2004 09:30 AM
Jeff Vader - boscoj
81
03-20-2004 06:42 AM
