Brake Pad's
Old 08-06-2010, 09:44 PM
tkinney80's Avatar
Default Brake Pad's
Ill make it short and sweet.
I own an 01 A6 2.7T and am looking for a new set of brake pads. Rotors were replaced all the way around the last time the Audi Dealer did the brakes so I think I will just do pads this time.
I am dissapointed that EBC doesn't make their "Green Pads" for this car. I drive only on the road and am looking for a pad that can handle spirited driving with low dust. Can you experts please reccomend some pads and a place to get them? When looking on my normal sites (tire rack, blauparts) I don't see anything that seems to stand out. What do you all recommend?
Travis.
Old 08-07-2010, 08:32 AM
tkinney80's Avatar
Originally Posted by clyde dove
Either your brakes are sticking,your foot is constantly touching the leaver or you bought the wrong,soft pads...
Say what? That doesn't make any sense at all. My post described no problems just that the pads are worn out and need replacing. I am looking for good suggestions.
Travis
Old 08-07-2010, 12:13 PM
nm3210's Avatar
Definitely, definitely Akebono. First off, do you have the HP2 brakes? That would mean bigger rotors and has FOUR pads per rotor. I bought mine off of Amazon.
And its a lot better to replace the pads and rotors together, but w/e - to each his own.
Old 08-07-2010, 03:53 PM
tkinney80's Avatar
I have not yet determined exaclty which brakes I have. I can tell that I have the brakes with 8 pads or four per wheel. From what I understand so far I need to determine if they are 312 or 321 mm correct?
Travis.
Old 08-07-2010, 04:00 PM
dandunham's Avatar
I really like the Akebono ceramics I have. they are very low dust but I don't use them under high loads so I cant tell you how well they work when you really heat them up.
My 2 cents
Old 08-07-2010, 04:06 PM
nm3210's Avatar
Yes, you have the 321mm HP2 brake system. If you're going w/ Akebono, you'll want the EUR839 8-pad set for the front and the EUR340A 4-pad set for the rear.
Link to DIY: https://www.audiworld.com/tech/wheel24.shtml
Old 08-07-2010, 07:31 PM
Redneck Truck's Avatar
Crap, I just paid $200 for the same pads from my indy who was supposedly "hooking me up". Lesson learned!
Old 08-08-2010, 08:11 AM
tkinney80's Avatar
If I decide to do rotors which one's would you all suggest?
Travis.
Old 08-08-2010, 08:12 AM
tkinney80's Avatar
I figure I might as well do it right. Let me know which rotors you suggest and I will order everything up.
Old 08-08-2010, 08:14 AM
nm3210's Avatar
If it makes you feel any better, the MSRP is supposedly $218.10 for front and $92.96 for the rear. But we all know that MSRP is crap.
Quick Reply: Brake Pad's
