Brake pads installed - brake pad warning light still on
I installed brake pads on the rear wheels of my 2003 A6 3.0 today (after a long afternoon that included a broken caliper spreader)
The warning light is still lit, though, even though the new pads are installed and the front pads look plenty thick from the outside. Is there something I need to reset?
If in fact your inner pads are worn significantly more than the outer pads you need to clean and relubricate the guide pins (floating caliper).
Checked today. Inner pads are pretty worn but should have a few weeks left in them at least. I have replacements in hand so I'll be getting that done soon.
Will the same Autozone/Harbor Freight caliper spreader work on the front calipers? I've done the rear pads a few times but never the front.
Sacer
01-09-2003 01:02 PM
