BRAKE PADS - SAME OLD PROBLEM
HAS ANYONE FOUND A PAD THAT WILL REDUCE DUST AND NOT SQUEAL FOR AT LEAST 75% OF THE LIFE OF THE PAD ? ALSO , ANYONE KNOW WHO IS MAKING THOSE FANTASTIC PADS FOR THE 2.7t?
Thanks
Thanks
Regardless of what kind of pads you use, if you install new brake pads on worn rotors it will have a tendency to squeal.. Softer compounds tend to squeal less but dust more, vice versa for a harder compound..
I have had good experience with REPCO Metal master pads, they dont dust very much, constructed of high quality and can be used on the track, but are harder on rotors, my recommendation is to spray anti squeal spray on the rotors before you install new brakes, it keeps the squeal away for a year or so but has to be reapplied every so often..
Gator Al (Al)
13
02-22-2006 12:58 PM
justinr488
03-09-2004 05:11 AM
