Brake wear light
2001 2.7T - 53,000 miles
The brake wear light just went on in my car and I took to the dealer (Nalley Audi in Alpharetta, Ga). They quoted $600 for new front pads and rotors, saying that they both needed replacing.
This doesn't make too much sense to me in that I thought rotors were good for much longer than the pads unless they were warped. Then I thought you could get the rotors turned if they weren't too warped.
A couple of questions...
Does this make sense?
Is this a reasonable DIY job? I have done this before with other cars and looking at the Audiworld site it doesn't look too difficult.
Does the light get reset if I get OEM pads with sensors?
I appreciate any advice or help.
N
N
brakes were great for 40k. The only time I would replace rotors is if they were deeply grooved or worn so thin there was a danger of cracking.
7 different models of cars and over 10 sets of brakes and I have never seen a warped rotor. Most "warped" rotors just have gunk on them. Put on new pads, bed them in properly, then do 4 to 6 panic stops to get the brakes good and hot and I bet that burns the "warp" right of 'em.
I'd replace them. Check out pure-motorsport.com for OE replacements (VERY CHEAP) and an extra piece of mind.
You can most definitely do this job yourself if you've done other cars. It is a very simple job. Just remove the wheel, caliper and carrier and bang the rotor with a mallet. Removing the pads is a similar job to other cars. You can rent a tool to compress the piston on the front or buy one from ecstuning.com for $35.
audi brakes. (and alot of german cars) Sure, you CAN do that, but there is a real good chance, your brakes will start squealing like a ****. im speaking from experience on my previous audi. the service center said, "theres a good chance your brakes are gonna squeal". I said, thats cool, ill take my chances. damn if they didnt start squealing like a pig in heat every time i hit the brakes.
Thanks everyone for the input. I am going to sell the car as soon as this is done, so I probably want to fix it correctly. I am going to try to do it myself and save some money. Keep the great advice coming...and again, thanks.
Nick
Nick
qwert1234
Q5/SQ5 MKI (8R) Discussion
14
03-22-2015 11:26 AM
sidespar
14
11-29-2004 06:30 PM
nanohead
07-08-2004 05:39 PM
