brakes, vibrate under hard/fast, not slow/soft
My brakes feel smooth as glass when braking normally. But when at highway speed and braking a little harder than normal the brakes vibrate quite a bit. They are fairly new (less than a year, before we purchased the car).
Warped?
Warped?
I installed an entire new brake setup about 8,000 miles ago, pads + rotors, everything, even new rear calipers. I have the same symptom, and i'm a nut about warping my rotors. I do not hot brake (leave the parking brake on after hard driving) nor do I EVER get them wet after driving. It would literally be *very hard for my rotors to warp with the amount of preventative care I take with them. Yet, I suffer the same symptom. I think that I am going to try swapping out my brake lines for stainless steel ones, I heard that it allows less expansion in the existing tubing when the brake is applied and creates a much better, stiffer brake pedal modulation. I will make a post once I purchase/install them.
Fixed the prollem...nice smooth breaking under all conditions.
So....how long will it last?
I am off warranty in a couple of day and a few hundred miles.
Maybe a StopTech solution is in my future!
timcar
10
06-01-2002 04:25 AM
Patrick B.
08-16-2000 08:51 AM
