Brembo BBK Fitment
Does anyone know if the Brembo Grandturismo kit for the C5 will have enough clearance for the Avus wheel? I run 18's most of the time, but have stockers for snow/spare.
TIA!<ul><li><a href="http://www.buybrakes.com/store/1B1-8002A">Brembo Kit Info</a></li></ul>
the Avus wheel is from the C5 S6 (17") the answer is yes! If the Avus wheel you have is a hartmann rep, both the 17" & 18" will fit over the Brembos. I should add that the Avus wheel from the B5 S4 (17") might work as well, but the off set is an issue.
X32, My answer is I don't know. If the caliper is the same, it should work, since that would mean that only the rotor is a little bigger.
btruby
02-20-2008 04:00 AM
Blue TooTh Fan
11-16-2004 05:49 PM
