Bubbling sound during inlet air pressure test!
I have a code for low boost pressure so I made the Y-pipe test fixture per the AWE Tuning recommendation expecting to find a cracked TBB or air leak somewhere. I have the main inlet and the 3/4 PCV inlet capped off. With about 10psi static pressure I hear no air leakage, but I do hear liquid gently bubbling steadily that stops when the presuure is disconnected. There are no liquid leaks anywhere.
If I block PCV valve (disconnected from the 3/4 outlet on the Y-pipe) I can blow oil out the dip stick tube.
The only symptom apparent when driving is harsher shifts. Ideas anyone?
(Cross-posted to S4)
normal. So your harsher shifts are probably the placebo effect. Stay under 10 PSI with the pressure test (looks like you did).
You're fine. : )
You're fine. : )
DWC_2.7T
03-27-2006 08:41 AM
expos
11-22-2003 10:42 AM
Rian Colorado
03-04-2003 08:02 PM
