Cam Tensioner gasket or Camshaft Seals?
Hello Everyone,
I have an oil leak on my 2003 Audi 3.0L V6.
I have done some research of what the problem seems to be like, but i am confused on how to take this job, since all of the write up seem to be made only for different models as 2.7. or 1.8L.
My question: I can replace the gasket myself, but does the 3.0 have a cam tensioner gasket or do i need to replace the camshaft seals?
Im not sure which one is it. Please let me know.
Please forgive me as I just bought this car not long ago, and I am learning a few things about it.
Thank you.
Thank you.
If you can do the valve cover gaskets, you can do the rest. My paper Bentley manual has valve cover gasket R/R for the 3.0 and it looks easier than the 2.7. It does not mention anything on cam seals and tensioner gaskets for any engine, but I followed the audiworld tech write up with no issues with my 2.7. I would assume that all dual overhead cam engines have replaceable seals and have a similar tensioner gasket. Note that a special tool is needed for the tensioner on the 2.7 and maybe it is the same for the 3.0. That said, 3.0's might not be subject to the same leak prone cam issues and you don't have to consider preventative replacement, if you're of the DFWAB school.
My XP computer finally booted the Bentley digital version and the 3.0 procedure is different and uses other tools, so disregard my optimism. Looks worse than the 2.7. Bentley discusses removing all the cam caps, which I didn't have to on the 2.7.
If the leak is confined to the valve cover gaskets, I might not do the whole works.
Bentley Publishers Home - Bentley Publishers - Repair Manuals and Automotive Books
Read the pc requirements in the FAQ's, since you run this on XP via kluge for later Windows systems. There is a beta online version with no XP nonsense, but I don't know how to get it.
I wouldn't do the repair without the on-line manual. Paper version is fine for some things, but incomplete.
The book looks expensive? The book will pay for itself!
Wait until you see what a certified technician's diagnostic bill is going to be and wonder if the guy is being straight about what needs to be done or if the guy knows about this engine.
For starters the AVK 3.0 does not have a chain tensioner or "cam tensioner" it has a cam adjusters under the valve cover, the only external seal outside of the valve cover is in the belt sprockets under the bolt cover buttons "No Biggie" and the cam position sensors have a paper gasket on the back of the heads.
The valve cover gasket is one continuous gasket, "easy peasy".
If you think you are loosing oil at the camshaft seals at the head behind the belt sprockets then look at the PDF, it's rare it see this because the 3.0 uses oil pressure to advance the valve timing via cams and behind the seals "possibly in question" are metal seal rings on the shaft ends inside the adjusters, I have doubts about this because you would have CEL codes indicating a problem on cam adjustments.
Thank you so much for your input. Calm down though, everyone is bond to see the best option. I do thank you for your help. Do you have the write up on valve covers for the 3.0. Does anyone one have it, I will greatly appreciate it!
Thanks cman, you are the man.
