Camshaft Seals and Transmission Seals
Has anyone done their own camshaft seals and transmission seals?
During routine maintenance on our 1998 A6, the dealer said that we should probably get the camshaft seal and the rear transmission seal replaced.
Is this a big deal and could I do it myself? I do most of all my own maintenance, but have never done these particular ones.
Is there anywhere in this Forum where these are described?
There should be something in the tech section.
For the rear seal, the exhaust has to be dropped to access this. Other than that, it's not a bad job.
Hi 4Driver4,
How does one pull the rear seal? Isn't it a press fit on? Therfore, how does one grab it to pull?
Unbolt the center drive shaft and move it out of the way.
Remove the bolt from the center of the flange, mark the location of the flange relative to the shaft in the center, and remove the flange.
Once the flange is out, the seal can be popped right out with a ply bar. Drive in the new seal, and put it back together.
To fix a leaking rear cam seal, I just need to remove the rear most cam holder and pop the seal off?
CK NYoC
12v V6 Discussion
08-22-2007 07:26 PM
audijim113
05-13-2006 06:42 AM
