Can anyone tell me how to remove the rear bumper
on a 98 A6Q. I have run a search but came up with nothing. I figure that there are bolts all around inside the trunk but if anyone has any experience and would like to share do's and don'ts I would be most appreciative.
Thanks!
Thanks!
Rear bumper
Rear bumper, removing, installing and assembly overview
1 - Bolt w/washer assembly
23 Nm (17 ft lb)
2 - Impact absorber
Removing and installing page 63-13
3 - Cross member
Bumper cover removed
- Remove bolt w/washer assembly and remove cross member from long member.
4 - Lower back panel trim
To remove, remove self-tapping Phillips-head screws -5- (6x)
5 - Self-tapping Phillips-head screw
1.5 Nm (13 in. lb)
63-12
6 - Bumper cover
Removing:
- Unscrew flanged nuts -10- (accessible through luggage compartment).
Luggage compartment trim must be partially disassembled
- Remove flanged nuts -11- (accessible through rear wheelhousing).
7 - Guide
Removing and installing page 63-14
8 - Screw w/washer assembly
1 Nm (9 in. lb)
9 - Wheelhousing liner
To access flanged nuts -11-, loosen rear half of wheelhousing liner
10 - Flanged nut (2x)
6 Nm (53 in. lb)
11 - Flanged nut (2x)
6 Nm (53 in. lb)
12 - Seal
63-13
Impact absorber, removing and installing
Removing bumper and cross member:
- Remove bolt -2- and impact absorber -1- from cross member -3-.
- When installing crossmember -3-, tighten bolt -2- to 23 Nm (17 ft lb).
63-14
Guide, removing and installing
- Remove bumper.
- Remove screw w/washer assembly -1- and remove guide piece -2-.
Tightening torque: 1 Nm (9 in. lb)
Item -3-: clips
63-15
Side panel, fastening
- Expanding clips -2- must be pressed in before installing cover -1- to side panel -3-.
23 Nm (17 ft lb)
2 - Impact absorber
3 - Cross member
1.5 Nm (13 in. lb)
63-12
6 - Bumper cover
Removing:
7 - Guide
1 Nm (9 in. lb)
6 Nm (53 in. lb)
6 Nm (53 in. lb)
12 - Seal
63-13
63-14
- Remove bumper.
Item -3-: clips
63-15
Theun
11-01-2007 03:31 PM
Richard Solomon
10-23-2005 07:01 PM
j31izzle
12-21-2004 06:52 PM
RidgeS4
01-01-2002 02:09 PM
