Can a single-DIN concert 1 headunit (cassette only) be swapped out for a single-DIN concert 2 (CD)?
Old 11-03-2007, 06:57 PM
New Member
Canadia's Avatar
Default Can a single-DIN concert 1 headunit (cassette only) be swapped out for a single-DIN concert 2 (CD)?
Anyone know if it's plug-n-play, or are the dimensions/interface slightly different?
Old 11-04-2007, 01:57 PM
audifirst's Avatar
Default yes it will work but you need Can-bus adapter
to get illumination , and disable 1 hours turn off
I have mine installed for almost a year, I did hardware modification to get illumination working, I have solder a wire on the board and wired to harness on the connector, instead can-bus adapter,
safe route is the adapter..
Old 11-04-2007, 05:22 PM
New Member
Canadia's Avatar
Default Thanks very much - do you know if the dimensions are *exactly* the same?
I'm mostly concerned with depth - I have the icelink ipod adapter installed, and the concert 1 *barely* fits all the way in with the extra wires. It would be very useful if the concert 2 was a bit smaller. Also, I've done some searching, but would you have any recommendations on where to buy the adapter?
Old 11-04-2007, 09:46 PM
GPZ
GPZ's Avatar
Default Well, DIN is a standard size, but I can't speak to the depth...
... I've often contemplated this conversion myself, let me know how it turns out!
Old 11-05-2007, 09:58 AM
audifirst's Avatar
Default the dimensions are the same as Concert I casette..
Adapter you can buy from Kufatec.de,
I had it orginally , but then decided to do hardware modification.
iphone newbie
12-28-2009 10:23 AM
mofologic
12-09-2005 07:16 AM
PaulW
11
01-08-2004 01:20 PM
Miwa
11-22-2003 08:27 PM
ORDan
12
09-11-2002 06:15 AM
Quick Reply: Can a single-DIN concert 1 headunit (cassette only) be swapped out for a single-DIN concert 2 (CD)?
