Can someone help me (vag-com codes)
Okay I pulled the following codes this morning;
Address 01: Engine
Part No: 4B0 907 551 K
Component: 2.7l V6/5VT G 0005
Coding: 06612
Shop #: WSC 02325
2 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
1 Fault Found:
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Sounds like a bad O2 sensor, not sure about the rest.
Thanks,
Aaron
Address 01: Engine
Coding: 06612
Shop #: WSC 02325
2 Faults Found:
Coding: 00160
Shop #: WSC 02325
1 Fault Found:
Coding: 15885
Shop #: WSC 02325
1 Fault Found:
35-00 - -
Thanks,
Aaron
Fear the Miata!
post this in the vag-com forum......looks like a bad o2 sensor as you suspected....<ul><li><a href="https://forums.audiworld.com/vag/">vag-com forum....</a></li></ul>
Okay thanks for the heads up, sorry didnt know about the vag forum ... LOL
Aaron
Aaron
MoyImola
01-02-2005 08:07 PM
