CEL again. Similar codes to last time but why would it disappear for .....
several weeks then re-appear?
Any ideas?
Address 01: Engine
Controller: 4B0 907 551 R
Component: 2.7l V6/5VT G 0001
Coding: 10712
Shop #: WSC 02325
WAUZZZ4BZ1N048536 AUZ7Z0Y1551952
3 Faults Found:
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
I guess it could just be a loose connection to the EGT sensor which is causing the two Lambda problems because the ECU is not picking up a sensible exhast gas temp?
I will have a look at it this weekend I hope, providing I get time.
Any ideas?
Address 01: Engine
Coding: 10712
Shop #: WSC 02325
3 Faults Found:
ODD8SHS
01-11-2011 04:22 AM
Edd W
04-02-2009 02:52 AM
Edd W
04-01-2009 03:21 PM
vitoal18t
10-01-2006 02:44 PM
