Changed MT fluid for Redline MT90/Amsoil 80/90 mix.
The Amsoil is synthetic GL5 with a GL4 rating so should be fine.
The shift is better, especially 2 to 3 and 3 to 4 which were stiff before, now much smoother. 1 to 2 is better when everything is warmed up but still a bit blocky when cold.
I think the synchromesh on 1 to 2 is just a bit weak for the job and it'll never be perfect.
Last winter, 1>2>3 were stiff, while 1>2 and 2>1 were REALLY stiff. :/
Did you just do a 50/50 mix?...what kinda volumes did the trans take?
Not sure about winter, some people say that MT90 sucks at low temps, not such an issue in CA.
There are 70/80 and 70/85 grades which might be better at low temps but I don't know if anyone on the forum has tried them.
but it will be too slick for fast syncro action.
Don't use GL5 in syncromesh trannies!
and it does require the EP rating for the torsen diff.
Would love it if someone could clarify Audi's spec.
Mark
Mark
while the dual GL-4/GL-5 rating means that you get the lubricity and protection of a GL-5 w/o the reactive EP components that can attack the synchros.
Motul 300 is a good example of one fluid that meets the Audi spec. Other synthetic gear oils may be good for the diff, but aren't 100% safe for the tranny.
Nkugs90
02-13-2009 07:16 PM
JUSTA4 -Matt
10-04-2007 01:27 PM
Bisqueth
13
03-18-2007 07:12 AM
FrancisB
09-24-2000 09:24 AM
