Cheap way to add vibrating seats!!....or just a rough idle.
#11
So no vacuum leaks and although I cannot verify if the intake runner valves are operating properly at speed, I did put it in gear sitting in the driveway and actuate the valve with absolutely no change in idle.
Maybe I'm simply imagining things.
I'm going to go reset the computer to factory settings with lemmiwinks and see if perhaps I am simply putting too much torque through the converter.
Thank you for all the insight. I'll be sure to take pictures and post through the trip back to washington.
Shortly after I return, this baby's going into the garage for a revamp.
I've got to replace the ageing cooling lines, all the plastic vacuum lines with rubber, softening suspension bushings and struts and just overall give her a cleanup.
I may even pop a supercharger on there for a little extra pep! I've been eyeing that PES kit.
AudiRyGuy
A4 (B8 Platform) Discussion
07-20-2021 03:39 AM
frankinstyn
01-13-2011 05:41 PM
golfindaily
12-11-2007 05:38 PM
bleone
09-09-2004 06:50 AM
