Check Engine.. need help here..
So I recently vaged my 2002 Audi a6 3.0l quattro and got thisL
Thursday, 23 July 2009, 00:06:49
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8E0 909 559 D
Component and/or Version: 3.0L V6/5V G 0004
Software Coding: 0016752
Work Shop Code: WSC 02335
2 Faults Found:
17930 - Camshaft Adjustment: Bank 2: Malfunction
P1522 - 008 - Implausible Signal
16409 - Bank 2: Camshaft B (Exhaust): Advance Setpoint not Reached (Over-Retarded)
P0025 - 002 - Lower Limit Exceeded
So my question is, what do i need to do or replace to get this fixed.
2 Faults Found:
Could be a lot of things. There is a procedure in the manual to test the cam advance system. There are four cams/four cam sensors. They are at the back of the valve covers, axial to the cams but at an angle. About $30 each at the dealer and a 5 minute job. I forget what bank B is, but I think it is on the driver's side. So it would be the cam sensor closest to the fender (exhaust) or the driver's side.
Do you have symptoms, rough idling or running?
deuxcv
Audi A3 / S3 / RS 3 MKII
09-08-2015 07:10 PM
