Chinese VAGCOM?
#11
The knock-off cables do not do everything the Ross Tech cables do. Knock-offs use VCDS lite and Ross Tech's use full version VCDS. Look at RT website for the differences. Minor, but some differences.
The Ross Tech equivalent of this knock-off is only $249, not $349 like keeps being mentioned. No HEX or CAN with the knock-off which means 2004 and earlier vehicles. The $349 RT cable will do all VAG's from '96 up to the ones rolling of the assembly now.
Knock-off cheaper yes, but you don't get support from RT and the cable may not work which means you will be out the $21 or be a PITA to get to work. Big deal, but if it fails after you bought the VCDS lite license then you will be out the $99 as well.
Just go for the real deal and you'll be set with no worries.
#12
5v,
We are in violent agreement. my point behind the whole thing is i got a dongle that worked out just fine (luck, divine intervention, using half my brain stem..etc) -- it worked out and cost me a fraction of what the RT cost.
Does it do everything, of course not, I never said it did. However, I dont need to drop $350(yes there is a $250, but seriously, are you going to shell out $250 for something that cant scan anything from this decade? I think not, most people are going to shell out $350 to be future proof, I would if I went the RT route) to clear codes, TB adaps, monitor mis-fires...etc
I'm all for legit, straight from vendor purchase(RT in this case) -- I always say "the frugal man always pays more" and " buy the correct tool for the job "
however, in some rare cases, Lady luck is on our side, and in this case it worked out.
As with everything, buyer beware, and your millage may vary(YMMV)
#13
5v,
I just know if you search the net you will find many negative reviews on the knock-off dongles. More negative than positive.
Let's just leave it as a knock-off VAG-COM is better than none at all.
#14
#15
5v,
Case in point, a flexible joint tool I kept in the toolbox for years split apart trying to remove the caliper frame bolts on my bro's passat. Went to sears and paid $12 for this single thing but, for lifelong, I never have to worry again right?
Finally, it all boils down to a matter of perspective and preference.
#16
-SlowSilverTIPJason-
VAG-COM Discussion
06-01-2007 05:03 PM
davenew
03-19-2006 06:21 AM
Boston1.8T
02-14-2003 10:03 AM
