Cleaned engine bay, now power steering howls.
Simple Green, water hose, plastic brush. Lots of water, though. Removed 6 of 8 coils and blew quite a bit of condensation out of them, now the engine runs smoothly again.
The power steering noise seems to be related to taking a turn in a lower gear (i.e. 30mph left turn at 4000rpm). Is this a pump wear issue or some relay? Or is the pump possibly sucking in air under load at high speed? There were a lot of bubbles when I opened the reservoir after turning off the engine. To answer the obvious question, the fluid is full and doesn't smell burned.
What does the PS fluid level read when the car is cold first thing in the morning? Usually bubbles happen when the PS fluid level gets low somehow and the pump starts churning air along with fluid. And how long have you driven it after the cleaning? Usually when my PS fluid drops and I get a noise, it takes 20 minutes or so of driving after topping up for all the noise to disappear.
The level says full whenever I check it, though I don't believe I've ever checked it cold. The fluid level hasn't changed since I bought the car.
I was thinking the bubbles might get in through a crack in a line that used to seal because of all the gunk built up on it. Is it possible that, after removing the gunk, I've created an invisible suction side leak that's letting air in?
