Clicking sound when I hit the Break..
I have a 2000 Audi A6 2.8 Quattro with 230,000 on it..
In the front end on the driver side when I hit the breaks (right after the front nose dives after hitting the break) ( whether or not im driving fast or slow or I hit the breaks hard or soft)under breaking I hear a click.. I can feel the click in the break pedal.. It has breaks with less than 5K - 7K miles on them.. and both front arms have been replaced.. Any suggestions.. Mike
Something loose? Retorque everything under there.
No break light switch.. Well the light is not lit i should say.. IM going to check the loose this weekend.. maybe the rotor.. ?? I'll repost after i check it.. Mike
loose lug bolts?
by brake light switch JustMe is referring to the normally on switch under the brake pedal. The brake pedal holds the switch open until you step on the brake pedal which then allows the switch to close and turns on the brake lights. Most brake switches are set up this way so the brake switch doesn't interfere with pedal operation.
Sometimes the switch becomes loose and maladjusted but (see above) that usually results in an always on brake light but I guess it could also go the other way...a loose locking nut on the switch would also allow the switch to move back and forth and click.
Due to the way you wrote the symptoms up, I'm still inclined to think something is loose down by the brakes.
XCLR8TT
06-10-2006 04:18 PM
MaXiTT
11-05-2004 02:35 PM
leonardl
03-15-2001 10:40 AM
