Coolant warning.
Have a 1998 2.4 V6 Quattro.
My coolant symbol in the autocheck is on constant and beeping when i start. Level and temperature is ok.
Disconnect the sensor on the bottom of the tank and see if the light goes out. If it doesn't, short the terminals and see if it goes out. If nothing happens, you've got a bad wire somewhere.
If the light goes out on either of the above, just replace the coolant tank or disable the sensor by leaving it disconnected or shorted (whichever shuts off the light) and check your coolant level old school.
2nd. Now he gets to look for dried coolant from a cracked tank...
$30 off ebay and it's OEM with coolant level sensor.
Visti
Canadian Discussion
10-20-2008 04:53 PM
SO i get the coolant light, does that come on ONLY when coolant level is low or even if mixture is..
white90+hibredS4
04-22-2004 03:52 PM
Seanism (clone510)
11-08-2003 01:32 PM
