CPO coverage for engine leaks?
Today I took my car (2001 A6 2.7T) to the dealer for service (Bell Audi in Rahway, NJ), and was told that valve cover gasket and cam adjuster seal are leaking, that these are not covered by my CPO warranty, and will cost me $1600 to fix.
I was amazed, since earlier they fixed my prop cam shaft seal leak under the CPO, and AFAIK any leaks which are not caused by external damage are covered under CPO. I suspect the dealer is playing games, since they would charge me more than the warranty would pay them.
I've contacted AoA, and waiting for their reply. I'm worried that the dealer may tell them that the leaks are because of "improper use" or something, and the AoA won't argue.
Would appreciate your advise, what I can expect from the dealer and AoA, and how I can "motivate" them both to have this problem covered.
Thanks a lot.
Thanks a lot.
AudiWorld Expert
which are NOT covered under CPO.<ul><li><a href="http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/product/certified_pre_owned.Par.0013.File.pdf">CPO warranty</a></li></ul>
contract (if I am using the proper term here) - if the component is not listed, its not covered. Some warranties list only what is not covered and thus all the other parts are covered. thus, CPO is not as good as factory warranty or the Audi Pure Protection (platinum level). I think you are SOL based on the brochure.
AudiWorld Expert
I too had some things covered under CPO that others did not, which is why I did not bother hunting for a CPO when I went shopping last year for the 4.2.
some will not. I've seen such lattitude under Factory Warranty as well. AoA seems to allow the dealers to adjudicate the warranty - the high volume ones they trust can do more work than low volume/problem dealers.
Ask nicely, but if the dealer says no you generally don't have a lot or recourse.
you can buy it separately and bring your car to an Audi dealership. That is what an independent dealer told me.
So you should be able to contact the warranty company directly and see what is covered.
Then you can tell the dealer to contact the same person at the warranty company if they say yes they cover it.
Some dealers are jerks regarding CPO, and some just fix everything as if it were the Audi warranty on a new car.
