CV BOOT Broke :(
Old 05-10-2006, 10:08 AM
  #11
donp's Avatar
A boot is cheap. Why throw money away.
Old 05-10-2006, 10:20 AM
  #12
Member
ado_dado83's Avatar
Default I HEAR the clicking noise only in the morning when I leave my subdivision
after that I dont hear it again till next morning.
Old 05-10-2006, 10:25 AM
  #13
donp's Avatar
if the joint IS making noise, then, yes. replace the axle.
Old 05-10-2006, 10:39 AM
  #14
Junior Member
john in cincy's Avatar
You likely now have a worse CV joint than you had before and less $ in your pocket. Congrats!
Old 05-10-2006, 10:45 AM
  #15
Junior Member
Actually, for $174, you now have an axle and CV joint that are pieces of junk.
Old 05-10-2006, 11:00 AM
  #16
MP4.2+6.0's Avatar
Default My experience and suggestions
Replace boot only IF no clicking noises and it has just recently cracked open. If any clicking noises or it's been quite a while (think road dirt, grime, winter crud, etc.) it's likely you should replace the half axle.
Once you pull out the axle to do the outer boot, it's very little more work to replace the inner one, though they don't crack open nearly as much.
Also if you lost one side just due to wear (as opposed to something phyically tearing it), figure it is just a matter of time until the other side goes. For my car, each side went within months of each other at just short of 5 years/60K miles. Replacing it early means less messy clean up, avoids unscheduled down time, maybe gets you a package price at the mechanic, and minimizes risk internals of joint will get messed up. Replacing the joint can add several hundred dollars to the repair cost.
While the axle is out, have the wheel bearing checked. The mechanic can simply spin it by hand to look for any signs of play or roughness.
Finally, look at all front suspension parts at the same time. Many postings on this, but if you are at the mileage where your CV boots are cracking open, your outer tie rods and upper suspension arms are likely to be worn or the rubber grease boots torn open. The lower ones may go longer. It's easy to see, you need to clean up the grease on these same parts anyway, and replacing worn ones also can solve shimmy issues.
Old 05-10-2006, 03:40 PM
  #17
Ritz's Avatar
Default A few reasons....
The amount of labor is more or less the same....and instead of a potentially scored up CV joint I've now got a new one and a new inner one all packed with fresh synthetic grease and new boots all around with all new hardware to boot. And I didn't have to spend all that time and deal with the noxious chemicals to clean and then repack the outer joint...and deal with the supreme mess it makes when you repack a CV joint. Well worth the extra $$$ to me.
Cheers,
Old 05-10-2006, 11:12 PM
  #18
brat2.ua's Avatar
I'd go for the axle...
Old 05-11-2006, 02:12 AM
  #19
Head Cat Herder
Kris Hansen's Avatar
Default Well, to me the money is the issue, not the time or mess. As long as the joint is ok,
I'd much rather reboot it..
Old 05-11-2006, 04:15 AM
  #20
Ritz's Avatar
Ah, you must be a Windows user.... 8-)
Quick Reply: CV BOOT Broke :(
