CV Joint Boot Replacement
Found both outer front boots split, so I'm in the process of replacing them. Got the driver's side axel out w/o having to remove the pinch bolt by removing the inner shield, but no such luck on the passenger side (still fighting that one).
The inner boots look ok, but should they be replaced at the same time?
2003 A6 Quattro 3.0
2003 A6 Quattro 3.0
clearance. Still need more? Drop the tie rod end but you shouldn't have. Just tighten the bolt back up with the car under load. Like on ramps maybe.
batsoff
10-30-2009 10:33 AM
