Dead A6 (P0321-Ign./Distributor Eng.Speed Inp.Circ Range/Performance)
#11
RTnDL let me know if everything is ok with your car now ... i have the EXACT same car with 80k miles and having the EXACT issue but the diference is that my car is only giving me:
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
and my mechanic menciones that it could be Engine Speed Sensor, but he did not want to change it because i was not geting that code and still to the day i am not geting it after almost 3 weeks with the issue.
so please let me know what happend and how much was it to see what my next step is going to be
thanks
thanks
#12
thanks
thanks
- P0321 - Ign./Distributor Eng.Speed Inp.Circ Range/Performance
Then "auidfirst " informed me that code should have read this:
- 16705: Engine Speed Sensor (G28): Implausible Signal - P0321
When I pulled the codes again after the car died a few more times I had this code:
- 16706 - Engine Speed Sensor (G28): No Signal - P0322
It does sound like you are having a very similar issue though. I would replace the sensor anyway if I were you just to rule out the possibility if nothing else. If your car still has the issue after that then just bring the sensor back and get your money back. It is not very hard to replace the sensor and most part stores have it for about $100 and even cheaper online. It may also have something to do with the code reader your mechanic is using as "frankinstyn" noted.
#13
Also, if the Engine Speed Sensor does not fix your problem and you still only have the one cat code then you may want to check that o2 sensor. That code is triggered by the o2 sensor in your catalyst. I have the codes for both cats because I drilled out the pre-cats behind the turbos on my downpipes to eliminate the backpressure. These codes were not related to my issue and I am pretty sure "2.7Lturbo" was shaking his finger at me when I noted this but that is why I have those codes. You only have the one cat code so I am guessing you do not have aftermarket or drilled downpipes. I must confess my expertise relies more on turbojet fundamentals as I have a background as a jet mechanic but I would not expect an o2 sensor to cause this issue..... This is where the Audi Pros chime in (;
blitz2003
08-31-2011 06:02 AM
Doctor Foster
12
09-18-2003 04:54 AM
