Dealer suggests cat replacements, any suggestions?
my '02 a6 4.2 is throwing out CELs PO421 (catalyst below threshold bank 1), PO431 (catalyst below threshold bank 2), & PO441 (EVAP small leak). the car gets loud around 30mph but doesn't have the tell-tale "rotten eggs" i've heard of when cats go bad.
took it it mcgrath audi in glenview,il and they quoted 4k to replace the 2 cats. could they have misdiagnosed? or would aftermarkets be a cheaper alternative? another what do you guys think?
My wife 2000 Passat with 2.8 V6, 70k miles, had the same issue. Turned out there was a software update and VW reflashed the ECU. From what I understand, the ECU was overly sensative to the temperture of the cats during warm up. The software update corrected that. $0.00 under warranty, $100.00? out of warranty. No more CEL.
Had them replaced at an indie with Magna Flow - car runs really well and still no CELs. Once off the car the old cats the guts just fell out!. High flow cats and the labour was less than $300.00 CDN. My gas milege improved slightly after the cats were done.
My 2.8 did the same thing and they flashed my ECU and the codes stopped. Saved $$$.
And those codes *could* be generated as a result of a evap. system leak.
Can't hurt to find a second opinion from an Audi/VW-specific independent mechanic. Good luck.
