Definitive solution to repair cruise control module 5GA 004 397-16
mtnbike01 (04-19-2020)
#43
2004 Audi TT Cruise Control Module
Hi New to the forum.. I have a 2004 Audi TT coupe Quattro
and the Cruise control does not work and I notice to fix online but I can't find the module... I have taken off the glove box found nothing and the panel by the driver and still not there. And yes it has cruise... Any idea please help...
#44
#45
99 avant cruise control not working
I have looked at the posts on how to fix the cc, but after I took out the cruise control unit I noticed that mine has a different number is 5GA006310-2 seen below. It has a different set up as far as the board so how do I fix the cruise control on this unit? Or other ideas on how to fix Cc. Thank you in advance.
#48
#49
I've re soldered the above mentioned components and even replaced my relay without any luck.
Does anybody have a link to the pin-out of the cable that connects to the module? (I just find some VW info online that doesn't seem to apply)
I would like to check that the stalk is working correct.
Cheers, Mike
Cheers, Mike
#50
Cheers, Mike
Cheers, Mike
You might try a used cc module first.
I would also have started a new thread, reference the old one, but resurrecting a zombie thread often gets little response due to the time it takes to find the latest reply….
