difference between tip chip and giac chip
what is the difference.i just read that tip chip help with shifting times. but how can that really increase horsepower (by 10hp)? how is that possible ....
99 2.8
99 2.8
it increases the idle torque and speeds up the shift times... when you hear of people talking about giac, apr, revo, oct, ams chips, those are typically ECU chips. If you have an automatic, I would highly recommend a tip chip as it helps get rid of the "sloppy" A6 shifting.
please clarify:
tip chip 1. does not increase hp
2. to feel difference, have to be using tip mode right
3. costs?
engine chip: 1. examples are giac, apr
2. same thing as ECU chip
3. increase hp ( by how much)
4. costs?
3. costs?
4. costs?
are mostly Tiptronic's. It work's in both modes. A GIAC Tip Chip costs about $250 for the 2.8 and $400 for the 2.7T
Engine chip produces about 10hp in a 2.8 and up to 60hp in a 2.7T, a GIAC Engine Chip costs about $300 for a 2.8 and $595 for a 2.7T
both prices taken from awe-tuning.com
check prices for other engines yourself.
Note: there ARE cheaper chip combinations
Th Giac Tip CHip does not increase HP. WOrks in both modes.
The Giac ECU chip is around $595
THe Giac Tip chip is $400 when purchased by itself and $300 when purchased with an ECU chip.
These prices are for the 2.7T model, I do not know if different $$ for 2.8 model.
Get both the ECu and Tip chip. Change your exhaust, will breath better, and lose a couple pounds.
Where are you located?
