disabling Secondary Air Injection System 2.7T - Beating a Dead Horse
I apologize for beating a dead horse-- I know there is a plethora out there about deleting or disabling the SAI system, but I can't seem to find any definitive "OK" or "NOT OK" to do. I have a 2000 Audi 2.7T Quattro. My SAI pump is noisy and about to go out, from what I'm told, and I'm cheap. So here are my questions:
1) Can I disable the SAIS without removing it and plugging a hole?
2) Can I simply remove the FUSE for the SAIS pump and call it good? (wishful thinking) If so, HOW?!
3) If not, can I just disconnect the SAI pump and leave it dangling? If so, HOW?!
Thank you!
Thank you!
You can't disable the the SAI system without reflashing your ECU. If you unplug it it, you'll get a CEL.
Also the fuse for the SAI pump also handles the o2 heater circuits, so you can't pull that either.
I appreciate the quick reply. If I unplug the motor, can I just replug it later, and the CEL will eventually turn back off?? I just don't want to sound like I'm taxiing for takeoff every time I cold start the car. As long as it will do no damage to the vehicle, I don't have any problem turning it off.
Thank you so much!! On my vehicle, the noise seems to be near the top rear of the engine, is that the correct location of the SAI pump??? On most other vehicles it seems to be under the front bumper, so I'm a bit confused.. But I'm fairly sure that's where the noise is originating.
Is it as simple as unplugging the plug that's right on the top rear of the engine?? Or am I being stupid and about to pull a plug that will destroy my engine?
This is a good tread. How do you reflash the ECU? Will the dealer do it or is it against N.Y. state emissons? My car is due for NYS inspection this month and my check engine light comes back on after a day or two after I clear the codes. Can the Ross Tech software flash the ECU? Anyone in the Buffalo or Batavia N.Y. have on that can help me out? Case of beer or cash reward.
Sooooo, do we actually need this then?
Mine every now and then squeals on first cold startup, but lately every few weeks im getting a 17831 and 17819 code relating to bank 1 and bank 2 SAI!
Does it do anything to the running of the car, do i need this to work for the engine to be at its best?
Or can i just ignore it and clear the codes when they pop up every now and then?
