DIY for Cleaning MAF
It's very tricky!
I tried this on my A4. I washed it in 90% isopropanol. Put it in a large zip lock, added the alcohol, and shook away. It didn't work.
Then, I tried a special pen (from Radio Shack) to clean electronic components, and I managed to rub a little too hard, and broke one of the two wires in the heart of the sensor.
I searched local junk yards, and found a sensor from a wrecked Jetta (compatable with the A4).
So my advice would be to get a new one from the dealer or a reputable seller.
Good luck! Let us know what happens.
I read here on the forums to use electronic tuner cleaner. Remove sensor from housing, spray,..
and let dry very thoroughly before re-installing. Electronic tuner spray can be found at Radio Shack or other electronic parts stores.
You can search on S4 (B5) forum, but the consensus there is isopropyl alcohol (90% + purity) and
soak it. The lower purity stuff (70%) has too much water, so don't use it. YOu could also try some spray on electronic contact cleaner.
you should be a little more respectful you dick
he's right, it is hard and cleaning the MAF rarely works. Usually, the cleaning is insufficient and the sensors rarely work properly anyway. There was a recall for these for a reason...they're fragile and can't be fixed as easily as you think.
Now if you're going to act like this to respected members of this forum you should go f*ck yourself and get away from here.
Luxus Panzer
09-09-2006 08:24 AM
CooliceTTT
10-06-2002 11:02 PM
808Guy
03-28-2002 05:15 PM
